flera bilder finns här http://s295.photobucket.com/albums/mm15 ... %20Clutch/
Over the last few month's Scotty Finlay (FRP) has been hard at it working on this clutch system to deliver you the very best from your engine.
With the advent of more and more powerful engines coming onto the market. He seen the need to transfer more power from the engine to the wheels more efficiently.
Engaging solutions.
With the Pro-MX clutch system Scott has taken already proven technology from his primary field of expertise. (Minimoto's)
During development of the Pro-MX clutch system he seen the need to break the current mold of 54mm clutch's and developed the 70mm fully adjustable clutch.
Why 70mm?
By changing the ratio between the engine and the drive wheels. (as shown below)
http://i295.photobucket.com/albums/mm15 ... pm_mph.jpg
The engine can deliver more power to the drive wheels. (As shown below)
http://i295.photobucket.com/albums/mm15 ... verlay.jpg
Providing faster acceleration (As shown below)
http://i295.photobucket.com/albums/mm15 ... x_time.jpg
We know how much you like to tinker so we gave you more options than you thought possible.
Even with the most highly strung of engines, the infinitely adjustable Pro-MX clutch system will allow you to be able to dial it in to perfection.
The clutch's bite point is set by pre-loading the springs
http://i295.photobucket.com/albums/mm15 ... G_3056.jpg
Spring adjustment tool.
http://i295.photobucket.com/albums/mm15 ... G_3075.jpg
The way the clutch sustains slip is adjusted by using different spring thicknesses.
From left to right 1.6mm Green, 2.0mm Yellow, 2.3mm Blue, 2.5mm Red
http://i295.photobucket.com/albums/mm15 ... G_3079.jpg
Further fine tuning can be made by adding weight to the BZM shoes.
http://i295.photobucket.com/albums/mm15 ... G_3072.jpg
Håller med till 100%. Fasiken vad dom krånglar till det bara för att kunna sälja till ett dyrare pris. Måste väl finns betydligt enklare konstruktioner som fungerar lika bra. Känns som om det går till överdrift med ingenjörsandan iblandLusse wrote:Snacka om att försöka att sälja mer.Mer kopliserad och dyrare.Vad är för delen???En riktig te-flon koppling måste vara bättre...
mest är det väl för att överföra kraften mer effektivt när man kör trimmade motorerhuSSe wrote:vilka fördelar har den fattar inte texten riktigt?
nån som kan förklara lite snabbt bara?
det där är ju en redan existerande som dom gjort om för att
passa våra motorer.
måste ju vara lika dyrt att fundera ut nåt helt nytt?
denna är 70mm istället för 54mm somär måttet på alla kopplingar i dagslägetWith the advent of more and more powerful engines coming onto the market. He seen the need to transfer more power from the engine to the wheels more efficiently.
