H.A.R.M SX-3 - The track sweeper
Phone Number: 0768033556
Re: H.A.R.M SX-3 - The Street Sweeper
Post by wrep » 14 Jan 2011, 22:10
MITT JOBB?? :D Du har ju en 3VC som du vill använda har jag för mig? ;) ;) ;)
såg på deras hemsida att de hade en sida på tjejj-book ;-) du hade ju sånt konto väl? :-)
sx3
Post by sx3 » 14 Jan 2011, 22:23
Om du mailar och jag tjejbookar dom, fan låter som ett bordellnätverk.. tjejbooka.. Iaf.. Den som får svar först postar, i annat fall är 2 starkare än 1 och dom kanske får för sig att återinföra det till framtiden ;)
Post by wrep » 14 Jan 2011, 22:29
he he... nu har jag mailat iaf.. som sagt må bäste man vinna :)
Post by wrep » 15 Jan 2011, 16:07
Post by S 500 R » 15 Jan 2011, 19:16
wrep wrote:http://www.horizonhobby.co.uk/autoonlin ... r_pro.html
ny version av DX3R ? DX3R PRO..
Den diskuteras i en egen tråd!
Post by wrep » 15 Jan 2011, 21:01
Jaha det har jag inte sett? vilken tråd är det då? :hmm:
Post by huSSe » 15 Jan 2011, 21:22
sx3
Post by sx3 » 17 Jan 2011, 18:12
Kjell skrev
Hello Futaba, I need your help for my 1/5 onroad gas car;
On the old T3PK Magnum, you could set the ATL on both ch2 and ch3 on same tuner, and there was also a function called "BALN" inte brake-mix where you could set the Balance between ch2 and ch3 within the set ATL and transfer the rate between front/right without changing the maxim...um brake capacity on one single tuner.
But the function BALN is removed on 3PKS/4PK/S, I can only manage to arrange the dual ATL with the free mixing, but how do I program a MIX function similar to the BALN on the newer transmitters?? And why have you removed this function as is is VERY convinient for setting up a proper brake mix!
Kjell, You can do what you want with the radio mentioned. However that explanation is really beyond what we can handle on Facebook. Give our Futaba tech support a call, they can help you out. Telephone: 1-217-398-8970 extension 2. Available Monday-Friday, 8am-5pm U.S. Central Time.
Nej, jag heter inte Kjell! Bara på facebook! :D
Okay, but I live in Sweden and paying a call like that to the US cost alot, and an explaination in text would be much easier for me to understand than talking in phone with a fast speaking american!
Could you at least try to explain on face...book, or let me have an email adress to someone on Futaba that could explain this over the internet for me?
Best regards!
Så långt har jag kommit med Futaba hittills :D
Post by wrep » 17 Jan 2011, 22:59
shit du leder... :-) mig har de inte svarat alls fastän att det står på deras sida att de skall svara inom ett dygn...
Men jag kan fortfarande vinna... he he :-)
Post by wrep » 18 Jan 2011, 08:55
Nu har jag också fått savr... fast mitt var också ett goddag yxskaft.... märkligt att det skall vara så svårt att läsa och förstå ett vanligt mail :-)
Per wrote:Here comes the problem:
I can´t get the brakemix to work the way I want on the 3VCS-transmitter.
Useing the 3PK I could make the ATL-function to transfer to ch3 as well as ch2 by activating "mixmode:mixed".
How do I achieve that in the 3VCS?
In 3PK brakemix there is "BALN" to change brake balance front/rear. How is that done in the 3VCS?
How are these funktions working in the new 4PKS? Is it possible to get the same funktions as 3PK regarding brakemix?
Deras svar:
Futaba wrote: Thank you for your recent e-mail. From what we can see in the programming of all three of thosetransmitters. The programming should be the same. However, with the4PKS you can do it on channel 4 also. Should you have any further questions or concerns, please do nothesitate to contact us at this email address.
sx3
Post by sx3 » 18 Jan 2011, 10:43
fan vad trött man blir! Jag högg tillbaka på facebook, så får vi vi se...
sx3
Post by sx3 » 18 Jan 2011, 18:04
VAD TRÖTT JAG BLIR!
Jag ringde upp USA och förklarade klart och tydligt vad problemet är och vad jag vill åstakomma!
Och det äckliga dryga arroganta svaret jag fick var "Jag har aldrig gjort det förut, maila oss så får du svar"
Vafan liksom, Wrep har mailat, jag har tjejbookat och nu ringt och alla säger att det går men ingen vet/kan förklara hur
Post by Burnout » 18 Jan 2011, 18:14
sx3 wrote:VAD TRÖTT JAG BLIR!
Oj... jag haft en sk*t radio till min gamla on road(såld) den har 2 fram och 2 bak bromsar.
min gamla radio hade 3kanal(fm40) den fanns inga expo eller annan.
då funkar inte alla bromsa bara fram funkar bra när jag kör med denna bil, helt tiden fram en par däck ryket... :doh:
Jag tips bra med 4pk den har flest saker i än annan många radio.... jag har själv en 16 kanal mulitplex pro..
denna kan använda på Ls bil som sagt förbjud på racing... :doh:
sx3
Post by sx3 » 18 Jan 2011, 18:44
Jo, 4PK sägs vara bra, det jag och wrep gör ni är att kolla om 4PK verkligen är så jävla bra, alla påstår att den har funktioner som behövs men vi hittar dom inte ;) Kanske kommer det blir en gammal 3PK för den verkar vara bättre än 4PK i broms mixning!
Vi gör ett nytt försök, mailade R/C@futaba.com (wrep, vart mailade du??)
Fattar dom inte det här då sliper jag av mig håret likt matadoren i tjuren ferdinand!
Hi Futaba,
I need a tutorial from you regarding how to set up a proper brake mix for my 1/5 gas on road racer.
On the old Futaba 3PK (not Super) you could find the options "BALN" in the brake mix menu, which transfered the brake capacity from front to rear or rear to front by adjusting the ATL on both ch 2 and 3/4 within the set EPA therefor you could adjust the ratio on one single tuner, eg, 100(F)/100(R) or 100(F)/80(R) or 80(F)/100(R) depending on which way you roll the tuner.
Now to the real problem!
On the 3PKS, 4PK and 4PKS there have been some updates in the software and the function BALN is now not to be found! I called my supplier here in Sweden (Minicars AB) And they said it's possible to achive and simulate the BALN feature on newer transmitters with the custom mixing but he did'nt know how to do it!
The only thing I mangage to setup with the newer transmitters like 3PKS, 4PK, 4PKS is to either increase or decrease the ATL on the ch2 and the ch3 on the same tuner, but not balance the rate between front/rear
So I sent a wall post on Futabas Facebook page and was told that it's possible to simulate the BALN feature also, but no guide in how to achive it since "However that explanation is really beyond what we can handle on Facebook" you replied!
So, I tried to call your tech support but the guy I talked to haven't ever tried to program a such mix, so he couldn't help me out but told me to send an e-mail to this adress!
So I'm asking you, before I spend 500€ on a brand new transmitter, could you please wirte me a tutorial/guide on how I simulate the BALN feature with the custom mixing on 3PKS/4PK/4PKS
So I can try and be 120% sure that this is possible! I would be forever thankful!
Post by S 500 R » 18 Jan 2011, 18:52
Hela denna diskutionen skulle ju inte ha varit i din tråd. Utan under radio och teknik. För denna tråden handlar ju om din bil, inte hur radion funkar!
