DDM:s deal of the day!
Re: DDM:s deal of the day!
Post by Lusse » 08 Nov 2010, 18:56
J.A racing wrote:
Bjuggen wrote:
jebogren wrote:är buzzen o led saker som man inte behöver men kan vara bra att eller
den killer bee som är på deal the day den funkar till spektrum vad jag fattat
Precis vad jag tänkte fråga. Funkar den med min DX3S??
Har du inte V1 i din Lusse??
Nja det är en speciel verision till Spektrum radios, kolla med Husse han fick fel och det funkade inte alls!
markusb skrev:
http://www.killerrc.com/faq/faq.php
"I have a 3 channel radio and no light controller. What Killer Bee should I get?"
Since your 3rd channel is not being used you should get the v1 Killer Bee. You can kill the engine with your aux switch. This works with any 3 channel radio, including Spektrums.
http://www.killerrc.com/faq/comparison_chart.php
Det går bra med v1 okså.
jebogren
Post by jebogren » 08 Nov 2010, 18:57
markusb wrote:http://www.killerrc.com/faq/faq.php
känns som detta är ett medelande från tillverkaren
Post by Bjuggen » 08 Nov 2010, 18:58
Kollade lite på killerrc hemsida. Beror tydligen lite på vad man har för mottagare.
Post by J.A racing » 08 Nov 2010, 18:59
Killer Bee v1 (tr210) works with all 3 & 4 channel radios. It plugs into the unused Aux channel on your receiver.
Killer Bee v2 (tr216) works with all 2, 3, & 4 channel radios, except HPI 2.4ghz, Spektrum and Nomadio brand radios. The v2 should not be used on helicopters.
The v2 is not necessarily better than the v1. They are just different.
The v2-S (tr217) works just like the v2, but it has a 5 second timer built-in that makes sure that the engine totally shuts down, and prevents the Spektrum failsafe from overriding the kill switch.
Post by Lusse » 08 Nov 2010, 18:59
jebogren
Post by jebogren » 08 Nov 2010, 19:03
precis det märker vi så snart
Post by huSSe » 08 Nov 2010, 19:06
så faatttar jag det oxå som.
läste precis.
Post by J.A racing » 08 Nov 2010, 19:10
jebogren
Post by jebogren » 08 Nov 2010, 19:23
Post by Bjuggen » 10 Nov 2010, 19:10
Bra deal idag. Desperadofälgar :thumbsup:
Post by J.A racing » 11 Nov 2010, 18:27
Post by Malte » 11 Nov 2010, 20:17
Hur är det med originalhubbarna av plast, är det något som brukar gå sönder eller är dessa att föredra?
Post by S 500 R » 11 Nov 2010, 20:28
Dom skulle man ju beställa!!! Måste fundera på det!
Post by Lusse » 11 Nov 2010, 20:31
Malte wrote:Hur är det med originalhubbarna av plast, är det något som brukar gå sönder eller är dessa att föredra?
Originalhubbarna håller ganska så bra , så vidare att det inte är kalt, för då spricker dom.
Post by Malte » 13 Nov 2010, 17:03
Tripp Wide Body idag! Svårt att se hur den ser ut egentligen med den lacken, men för mig blir det nog Woodster Wide V2 istället. Tror jag. Har inte sett någon bild på den ännu men...
Är det någon här som kör med Tripp?
http://www.davesmotors.com/s.nl/c.88503 ... id.7663/.f
Users browsing this forum: Bing [Bot] and 15 guests
