Allt om KRAKEN VEKTA.5
håkan
Phone Number: 0768964228
Re: Allt om KRAKEN VEKTA.5
Post by håkan » 14 Jun 2016, 13:08
Yes :-)
Convert it :-)
Markus R
Post by Markus R » 21 Jun 2016, 22:22
Looks really nice!! And im with S 500, don't convert it, that machine needs to scream!
Skickat från min Nexus 4 via Tapatalk
HPI Baja 5b
Post by S 500 R » 22 Jun 2016, 08:18
Good choise :thumbsup:
gcbossen
Post by gcbossen » 01 May 2017, 12:31
När kan man köpa dessa i Sverige?
Baja 5T OBR 30,5 VRC BigBore
Baja 5T G320 Dominator
3PM-X
Post by KaptenMagnus » 01 May 2017, 17:55
gcbossen wrote:När kan man köpa dessa i Sverige?
Du kan höra med tex Rc maffian så kan Jens säkert ta hem till dig Image
Det är nog ingen handlare som har dom i lager utan det blir beställningsvara
JeffryC
Post by JeffryC » 13 May 2017, 10:59
Started the conversion with the Wheelman Designz Conversion kit:
http://www.davesmotors.com/WheelMan-Des ... kta-5.html
Setup will be as follows:
TMM 40063-3 for Cars X2-SERIES (ordered, being build)
ON/OFF switch
WP version (increased protection against water)
design with active FAN cooling (2 × FAN)
power conductors 10.0 mm2
set of external capacitors
MP JET 1.8mm (recommended for integrated AntiSpark)
connector 8.0mm (5x)
please solder these connectors to controller
Castle Creations 2028 800KV brushless motor.
2 X 9500MAH 75C 5S lipo
2 X 7600MAH 70C 4S lipo
Speed is not what I aim for, I just need to find the sweet spot with this setup. :D
Working on the Vekta is very straight forward and it has been the best RC vehicle I had to work with hands down. One of the things is though that they can be heavy on the loctite, but it worked out fine.
Installing the brushless setup is thanks to this kit incredibly easy, and it beasically removes the need for relatively heavy mods to get to brushless on the Vekta.5
Came back from the States yesterday morning and wanted to directly build this thing in. Who can blame a fanatic?
Updates will follow, need to wait 2 weeks for the ESC, but we are patient...
Andren
Phone Number: 0766120140
Post by Andren » 13 May 2017, 15:49
So you did change your mind and it wasn't run over......... but i already knew that
Losi 71cc Rcmax
Skopod 62cc Kraken vekta 5
Outlaw hybrid 32cc
Losi 5b
HPi baja
