RCMK K30
Diverse diskussion om båtar
jebogren
RCMK K30
Post by jebogren » 29 Dec 2011, 18:50
är lite sugen på att köpa rcmk nya serie med cylindrar till skater dom sägs ge ca 7hp
http://www.gizmomotors.com/index.php?pa ... &Itemid=56
jebogren
Re: RCMK K30
Post by jebogren » 29 Dec 2011, 18:54
en skater med k30 twin dock parale monterad
jebogren
Re: RCMK K30
Post by jebogren » 30 Dec 2011, 17:35
Dear Daz,
Thanks for your mail.
We will supply the K30 Top End kit for Side Exhause engine and Rear exhaust engine(R254, RX254, RZ254) to our all customers in the world at soon.
And, the K30 piston and K30 cylinder is really perfect and excellent performance for Rear Exhaust engines.
So, if you use the K30RZ Top End kit in your RZ254Evo, you will be very good pleasure for excellent performance and without any problems.
The K30 Top End kit price - 175.00USD
We finished the K30S testing on the water and Dyno tester.
The K30S performance and quality is really excellent.
feild testing on the water
48 inch mono with 7020 mod prop -  67 mph
Dyno testing
7.2 HP at 14,000 rpm with 2.8 foot ponds of toque.
Peak RPM : 19,000
This above K30S is really stock engine.
The K30 cylinder, K30 Top End Kit and K30 engines will become a best seller for RC Gas boat.
Moreover, We will produce the below K30 engines.
 K30S, K30S-R, K30SX. K30SX-R, K30RZ, K30RZ-R,
K30R, K30R-R, K30RX, K30RX-R, K600S, K600S-R.
And, we will produce and release the "CR290" Top End kit of CR290 complered engine within this month.
And after, we will produce and supply the completed CR290 Car engine.
We will finish to produce the CR290 completed engine within this year.
The CR290 cylinder and CR290 completed engine will have excellent power as like K30 Marine engine.
Because, the CR290 cylinder inside bore form and dimensions are exactly same with K30 cylinder inside bore.
Our CR290 Top end kit and CR290 completed engine will become a storm for RC Gas Car market in the world.
Thank you.
Yours truly,
RCMK
From Mr.Park
So as you can see i didnt just get them figures of the BS internet,got them from RCMK themselves,i always check before and research before i buy or post anything
jebogren
Re: RCMK K30
Post by jebogren » 01 Jan 2012, 10:55
om jag har fattat rätt så ska man använda detta på en zenoah vevhus så ska man ha 1mm eller 2mm vev
tror det gäller alla rcmk toppar till zenoah vevhus om jag har förstått jockerracing rätt
får bli att leta efter något annat
JPH har K600 twinen i sin kolfiber båt ska bli kul att se hur den går i sommar
