winter tires, those who needs them
Posted: 24 Oct 2012, 20:54
Ok homies...
How many you guys are stuggler winter and ice??
Well, here is how i do deal the ice and snow..
My tires were hostile mxt, but you can use also hostile mx and minipin tires and proline bowtie tires, well, these i have used.
First you need to drill hole on the tire, 4mm drill is good.
And DO drill the hole center of the knob..
Turn the tire up side donwn ,and start to drill the metal sheet screws in to the tire, with those holes you did drilled just before.
Be gently, low rpms.
http://www.youtube.com/watch?v=eu9e4p49 ... ture=g-upl
I used 13mm metal sheet screws.
In front in the middle i used only one and second know gets the screw.
On the rear, i used all the knobs, so there is in every know this very sharp screw.
And do remember, on the front tires do it as zigzag
This is the best way you can get the grip on the ice..
