The New HPI Baja 5sc with radio control !!!OUT NOW!!!
Posted: 09 Feb 2011, 11:01
HPI Baja 5sc with 2,4 GHz radio control with red or black body to choice, set
Jump into the thrill of Short Course racing with the Baja 5SC truck from HPI! The Baja 5SC takes the HPI Baja line-up to the next level with a new SC-1 body that gives the Baja 5SC authentic Short Course looks. Adding to the durability and realistic looks is a new skid-plate front bumper and a large rear bumper with real rubber mud flaps. Power comes from a massive 26cc Fuelie engine that propels the Baja 5SC to speeds in excess of 40mph and it runs for more than 45 minutes on a single tank of regular unleaded pump gasoline. For extra traction on any dirt surface, HB Rodeoo tyres are now standard equipment, mounted on new TR-10 bead-lock truck wheels. We increased durability with Super Heavy Duty 9mm drive shafts, updated rear hub carriers, and HD front hex hubs. A 2.4GHz radio system is standard equipment for precise control and long distance reception without the hassles of frequency crystals. It's all ready-to-run right out of the box, pre-assembled by our expert crew so you can hit the dirt quickly.
New Baja Short Course Parts
The Baja 5SC is fitted with a wealth of awesome Short Course parts that make it ideal for tackling off-road tracks shoulder-to-shoulder with hordes of other racers. Check 'em out!
New Short Course Body
The wide Short Course body is the first thing you'll notice about the Baja 5SC: it's more realistic than the Baja 5T body and it fits completely over the new wheels and tyres to let you take corners deep, run the competition wide coming out of the corner and really bang together with other trucks! The Baja 5SC comes pre-painted in your choice of black or bright red, each with color coordinated graphics.
New Heavy Duty Front Wheel Hubs
To keep in sync with the new Super Heavy Duty drivetrain, the Baja 5SC also comes with new Heavy Duty front wheel hubs. These new axles utilize a screw and nut design that eliminates the older e-clip design, which further improves the reliability of the truck.
HB Rodeoo Short Course tyres and New TR-10 Wheels
For high traction on a variety of dirt surfaces, HB Rodeoo tyres are standard equipment on the Baja 5SC. The asymmetric tread pattern mirrors the design of full-size off-road racing tyres. The sticky rubber compound, block treads and wide grooves give the right mix of sliding and gripping. Concentric rings on the sidewalls give extra grip if things get really hairy! Bold new 10 spoke wheels (TR-10) using heavy duty beadlock rings add to the realistic Short Course looks of the Baja 5SC.
New Front & Rear Short Course Bumpers
The final touch in completing the scale look of the Baja 5SC is a new set of bumpers that allow you to give your fellow racers a 'love tap' without risking a major incident. The bar-style front and rear bumpers look great and, along with the mud flaps, add that extra bit of Short Course realism!
New Adjustable One-Piece Rear Hubs
New rear hubs have been added for increased durability and easier adjustment of the toe-in setting. The new hubs are lighter weight and allow toe-in adjustments of 0, 1, 2, 3, and 4 degrees to help match the truck performance to track conditions.
Super Heavy Duty Parts
Because of the ever-increasing power demands of Baja owners around the world, and the constant desire to cram as much power in the Baja chassis as possible, we've added all-new SUPER Heavy Duty drivetrain parts that will make sure the Baja 5SC can handle extreme conditions and massive power!
- Super Heavy Duty Drive Shafts
All-new extra-thick 9mm dogbones are the starting point of the 5SC drivetrain upgrade - these are new, thicker and stronger to outlast the roughest rides and racing action you can find! New wider rubber boots are included to keep the dirt and mud away.
- Super Heavy Duty Diff Shafts
Getting the power from the diff gears to the new dogbones is a wider diff shaft that perfectly fits the increased diameter of the dogbones.
-Super Heavy Duty Drive Axles
The Baja 5SC is fitted with new Super HD drive axles to get power to the rear wheels, which fit the thicker dogbones.
HIGH QUALITY ELECTRONICS:
TF-20 TRANSMITTER and RF-30 RECEIVER
Controlling everything is easy with the HPI 2.4GHz radio system. There's no need to worry about changing crystals, the radio prevents frequency conflicts automatically. Water-resistant servos control the steering and throttle/brake, with the powerful large-scale SFL-11MG steering the front wheels. If the truck loses radio signal or battery power, an electronic failsafe will bring it to a safe and controlled stop. The servos are powered by the included 3000mAh NiMH 5-cell battery pack, you just need to supply a charger with standard battery plug and 6 AA batteries for the transmitter.
SPECIFICATIONS:
Length: 900mm
Width F/R: FRONT 440mm / REAR 460mm
Height: 320mm
Track F/R: FRONT 370mm / REAR 380mm
Wheelbase: 570mm
Weight: 12.6kg / 27.9lb (without fuel)
Our price: 1249 €
Link to the onlineshop with red body:
http://www.rc-car-online-shop.de/lshop, ... 235,,,.htm
Link to the onlineshop with black body:
http://www.rc-car-online-shop.de/lshop, ... 237,,,.htm
SPECIFICATIONS:
Length: 900mm
Height: 320mm
Wheelbase: 570mm
Our price: 1249 €
