The new geometry of the front hubs in connection with the new CFK- front axle reinforcement facilitates higher speed in corners.
Another advantage is the very good traction with inclined tyres what facilitates early acceleration in corners.
Also wear at front and rear axle is reduced.
The new geometry requires also modified a-arms front upper which are also included in the set.
