Bygg en Zenoah G340RC longblock ~2300kr! (i USA)
Post by Malte » 01 Apr 2015, 12:32
Hittade detta tipset på Losiforumet i USA, priset är utan frakt tull och moms dock!
On a budget and looking to buy a new motor? Might want to consider this...
http://www.davesmotors.com/Zenoah-Co...or-G320RC.html
If your new to the new zen 38mm platform, you will also need to purchase:
1) G320 clutch housing ............ 26.99
2) G320 engine cover.(plastic)....12.50
3) G320 manifold & gasket.........11.50
4) G320 wrist pin bearing........... 4.99
You can use all the extra needed parts from your old engine including, flywheel, flywheel housing and pull start, coil, spark plug, clutch holder, clutch, clutch bell and pinion and even your existing carb, gaskets, airfilter etc.
You now have a new Zen G340 for $254.98
